Usage not showing
Okay. This is most likely something the reps will need to address, but in order for them to do so you should repost this on the Tech Support section.
In the meantime, you may be able to see your data through the Usage Meter, which you can download for Windows at the myAccount site (you don't need to sign in).
There is also a mobile app for Android and Apple devices. You can download it through their corresponding "stores", which you can find by searching for it on Google. Just search "HughesNet mobile app" and you'll see them listed.
Edit: I see now that you already did create a new topic in Tech Support.
I check it under my account and usage. I usually check it daily, but it still has this error message day 3.
