6.6.0 Usage meter - Data Cycle Info Missing
I saw that quoted text too, and some other similar, but obviously it's not showing anymore which is part of why I started this thread. I'm in the area where it should be giving me those warnings, and it's not telling me that says I'm all good, and and the other info missing is why I was concerned it's a glitch. Plus when I moved to Gen4 Amanda had to switch our plan around a few times due to her offering us a discount, and we had to juggle it with a type of plan/discount that worked with the status meter (First plan didn't work with it right, due to how the discounts were applied). So missing this important info made me concerned for two reasons, mainly the info was missing so it appears to be a bug like before when that happened, and two I thought maybe this was due to what we ran into previously with our plan layout and discount being setup an unusual way.
I was using 6.5.3 x64, it works properly for us.
Check your personal messages, use at your own risk, give to no one else... >.>
- cybo549 years agoJunior
I will keep to myself, but can't check that out until later tonight due to limited internet ha! :smileylol:
I sent a different link this time specially for you, only about 7KB in size I think instead of 100MB+. :) Let me know how it works or if you run into any issues.
Thank you, working fine and I just replied!
Hopefully staff will reply about these removals, or many others will join in all over again and voice their concerns on how benificial this info was for the status meter to provide.
