6.6.0 Usage meter - Data Cycle Info Missing
Thanks for confirming! I noticed all the different available "modem plans and states" the program compares when choosing which info to provide the user, and with what I ran into before with a out of normal plan setup made me think maybe it's just due to that, but I guess not if it's that way for you too.
On your edit. I assumed it wasn't from that, but seeing similar data output mentioned there made me think maybe it was just our plan setup again because it looks like both old and new generate that same info based on that js file.
I know what you mean about edits, and since I'm not good with java I wouldn't have been testing any edits anyway just looking around.
:smileyvery-happy: Got a good laugh out of that token comment, now find where one wrong edit makes our monthly allotment 100GB anytime and we'll all be set :smileylol:
Yeah... that's something controlled at the NOC and might have police knocking at your door at 6AM the next day... LOL
- cybo549 years agoJunior
Ha, yes I was joking!! :smileyvery-happy:
I know that wouldn't be possible anyway, maybe make it appear that way on our end, but I know all that's set on their side anyway :smileyhappy:
And see, this is why I thought maybe some issue with the way our plan/discount is setup that's causing some of what I noticed missing.
We're out of data for the month and the new status meter does not show smartbrowsing, while the old one does.
This is same issue we found before with old status meter, smart browsing didn't show due to the way our plan was setup and Amanda had to switch things around a bit.
- foxbrook9 years agoSophomore
I also want to give a big thumbs down for the new status meter. I've got my kids (10 and 13) trained to use to old status meter to monitor our usage, now that information is obscured in the new status meter.
Fortunately I still have a copy of the old status meter and will stick with that for as long as possible.
