New plans - price way up - data allowance way down...help?!!
Is there some reason that you can't stick with what you already have? I'd advise that you do so. Many people on the Ultra plan are doing the same.
Gen5 was available for everyone in the lower 48 starting in March of 2017. But, because beams are filling at varying rates, what's available in one area may be different than what's available in another area. Basically, what you see available for your area is what you can get, and because of that I would stick with what you have.
Well, I surely hope I can do so......that would be ideal - and somehow had the idea I had to change plans - but if I don't I sure will stay with what I have!!!
Good choice. To be honest, the only real advantage that you might have with Gen5 is faster speed, but that's only a might, and to what degree is hard to say, or even if you would see it. Gen5 also has the new modem with the built in WiFi, but you can also do the same thing with a 3rd party router. And, with what you would lose, both data and price wise, it definitely isn't worth it. That's just my opinion, of course.
The only reason I ended up going to Gen5, from Gen4, was due to them offering a plan that had 5GB more data, but for a bit less per month due to the offer at the time. My bill's about the same, now. My Gen4 service itself was great. My folks, who are right across the street from me, still have Gen4, and they have no plans, or reason, to upgrade, either. If I had originally gotten the Gen4 Ultra plan, I'd almost assuredly still have it.
I know of one other person on here who has the Gen4 Ultra plan, and they're a long time Community member. They have no plans on upgrading, either, so you're in good company. :)
GabeU wrote:Good choice. To be honest, the only real advantage that you might have with Gen5 is faster speed, but that's only a might, and to what degree is hard to say, or even if you would see it. Gen5 also has the new modem with the built in WiFi, but you can also do the same thing with a 3rd party router. And, with what you would lose, both data and price wise, it definitely isn't worth it. That's just my opinion, of course.
Yes, myself and many others on Gen 4 Ultra plan are just fine staying put especially at $90/month. We were lucky to get it when offered way back when and offer didn't last long. Personally speed is fine for two users, wife and myself, sometimes 30+ mbps and still fine right now going into prime time.
EDIT: The newer modem isn't better IMO unless you're looking for a free WiFi router and don't already have your own router.
