Hudon4
6 years agoNew Poster
Streaming problem
My daughter can't stream her classes for college and they are all online, need help with speeds, have 20 g plan, would 30 g be any faster?
Kbcabe513
6 years agoNew Member
We haven't event nearly reached our data, and it continues to buffer. Its super annoying. We cant even watch a whole movie with out it stopping every 5 seconds. And we thought that going from the 20 to the 30 might help also. It dont, save your money. Haha! I just think it is just an expensive amount of money to pay for a service that doesn't really work.
Everything that the guy above has mention we have went through with the advanced tech support. And nothing has been done. Nothing changes. At least not for us.
Good luck to you!
Good luck to you!
As an alternative to streaming, you may want to look into PlayOn Cloud. Your chosen streamed item is recorded to a cloud based DVR, then converted to an mp4 file, which you can then download manually, automatically or by scheduling. You can then watch the item on any device that can play mp4 files, which most can these days, including Smart TVs directly from a USB flash drive or USB external hard drive. There's no buffering because you're watching it from an already fully downloaded file. The file also never expires.
