Liz-
-Kent
What is the modem plugged into? I ask this because you mentioned that you have to "reset the power." What is it you do when you reset the power?
- coppcabin7 years agoFreshman
By resetting the power, I mean that I simply unplug the power cord from the power source and plug it back in. The satellite modem will not reset on it's own once all the lights on the front go out. Strangely, the link lights on the back of the modem for the wired Ethernet ports continue to show activity even when all the lights on the front of the modem go out. However, wired devices also don't work and can't access internet when the problem occurs. It's almost as if the satellite modem is in stand-by with power applied but it's not booted up and running.
- Liz7 years agoModerator
Hi coppcabin,
Thank you for the additional details, let me investigate further into this for you. I'll post back once I have any updates or additional questions.
