Liz-
-Kent
All good, Kent, thanks for the update!
I was back at the cabin again, finally. I moved the modem's power source directly to the wall outlet. Later in the day it went offline like it always does (all lights are out on the front and internet went down). I took my laptop and hardwired directly to the modem. I didn't get an IP address via DHCP so I set a static IPs on my laptop for testing. I could not ping or otherwise access 192.168.42.1 or 192.168.0.1. However, I could still connect to other network devices that were connected to the back of the built-in 4-port switch on the modem. So when the modem goes "offline" the built-in network switch still passes traffic between devices, but the modem itself is not accessible and internet is offline. I waited nearly an hour to see if the modem came back online on it's own and it did not. I unplugged the power and plugged it back in, and as normal the modem came back online.
If it's not the power source and I've replaced the modem and power supply, what else can be causing this???
- Liz7 years agoModerator
Good morning Kent,
I appreciate the update, this is pretty unusual. I'd like to get one of our modem experts here at corporate to have a look at that modem. Instead of sending another modem out, I'd like to get a tech out there to review the site and switch the modems. I'll have the tech ship the modem to our engineer so you don't have to worry about doing it yourself. Considering you're not always at this site, I won't set a particular appointment date, but rather the assigned local dealer will reach out to you to make arrangements. Is the number ending in 02 the best number for them to call you?
- coppcabin7 years agoFreshman
Liz-
That sounds like a reasonable plan since I don't know what else to do. Now that the weather is cold I'm only at the properly on occassion, but I can work out a schedule with a local dealer like you have suggested. Best number to call is the one ending in 37. That's my mobile. Thank you!
