HT2000W Red Power Light, White System and White Receive lights
Okay, sounds like the modem might think its overheating and putting itself in this state, so we will need to replace it after all. I will be shipping you a new modem at no cost. The box it arrives in will have a pouch with a pre-paid shipping label that you can use to send back the old one to us. Because of the holidays and upcoming weather, it may take a few days to receive the modem. Though it might not be overheating, leaving the modem plugged in to power isn't recommended just as a precaution. I am also going to be sure to credit you for your time without service. Let me know if you have any other questions or concerns.
Have a safe and happy New Years!
- Mindiefish8 years agoFreshmanOk. Thank you for your help. I appreciate your quick response and great service. Will you be sending tracking numbers? Also is there any other setup requirements once the new modem is received or is it just “plug ‘n play”?
Thanks again!!- Amanda8 years agoModerator
I can get you a tracking number once it is loaded into our system (after UPS sends that info to us). The modem is plug 'n play - just move the coaxial cable from the old modem to the new. The replacement should come with its own power cord too. Allow the unit to sit for at least 20-30 minutes to register. We have not yet uploaded the HT2000W replacement guide, but the guide for our HT1100 is essentially the same: http://support.hughesnet.com/sites/support.hughesnet.com/files/inline-files/1039585-0001_g.pdf
In case you want this too, here is our HT2000W user manual: http://support.hughesnet.com/sites/support.hughesnet.com/files/inline-files/1041318-0001_c.pdf
~Amanda
- Mindiefish8 years agoFreshmanGreat! Thanks again for all your help!!
Happy New Year!
