I cannot RECEIVE INCOMING Phone calls??
I cannot receive any incoming phone calls.The last time I had an incoming phone call was on 05/11/2020 - I have a dail tone and CAN make phone calls out.I searched the community board on my subject and found and old thread discussion with a customer who was having the same issue as I am.I followed ALL the trouble shooting suggestions on that thread as the technition advised and nothing worked.When my husband calls me from his work he tells me when he gets home from work that everytime he trys to call he gets message that my number is no longer in service.When my daughter who is at home with me calls my phone number from her smart phone she however gets no message and told me that the call won't even go thru.All my lights on the ATA are the colors they should be EXCEPT the LAN which has no lit light at all.What is going on with my VOIP phone service please??
Hi Sharon, no, no need to do that, I'll just send you another ATA which will come with a new LAN cable. You won't have to return the old ATA either.
Hi Sharon,
Can you please check if you have a dial tone now?
- LizModerator
Hi Sharon,
I see it's your first post here, so welcome to the community! I appreciate you telling me what troubleshooting steps you've taken so far, please also link me the thread you were referring to so I can document what you've tried. I've already pulled up your account and have started investigating your case.
- sharonmosesSophomore
Here is the community forum link https://community.hughesnet.com/t5/Tech-Support/WAN-light-yellow-all-others-green-Can-t-receive-incoming-calls/m-p/116607#M78708
- LizModerator
Thanks Sharon!
Do you have another LAN cable you can swap out with the one connecting the ATA to the HughesNet modem? If so, see if you can change cables while ensuring that the different cable is secured with a click on both ends. Let me know if that LAN LED comes on and/or if you can receive calls then.
