Increased speed after exceeding the monthly data plan.
They have not said what throttled speed will be. Regardless of what speed they have increased it to, you should not expect to get that speed, as speeds are (1) not guaranteed (see the subscriber agreement), and (2) dependent on many variables, including traffic. Speeds currently are much slower because of all the people at home using the system at once.
They will not increase data caps. Satellite internet is limited, and all subscribers must share this limited data. Unlike terrestrial cable, satellite ISPs can't increase caps without launching new satellites.
Best practice: budget your data allowance and do the best you can with the data and speed you have.
Albert_S wrote:
I saw this posted in the annoucnements - "we’ve increased the speed you receive if you exceed the amount of data in your monthly service plan". What speed should we be getting? It seems like this hasn't increased (last test download = 2.3Mbps, upload = unmeasurable). Also, is Hughesnet thinking of increasing data limits since many of us are working from home?
Thank you,
Albert
If you're seeing a noticeable difference in speed between when you have data and when you do not, and you need the higher speed for something, purchasing data tokens may be of benefit to you. However, if you can deal with the throttled speed after you've exhausted your data, I wouldn't bother. Plus, as time goes on, the speed of the service while you have plan or token data will likely drop due to the ever increasing strain on the system.
So, whether you buy tokens is really up to you, but I would make sure you really need to before you do.
Albert_S wrote:I saw this posted in the annoucnements - "we’ve increased the speed you receive if you exceed the amount of data in your monthly service plan". What speed should we be getting? It seems like this hasn't increased (last test download = 2.3Mbps, upload = unmeasurable). Also, is Hughesnet thinking of increasing data limits since many of us are working from home?
Thank you,
Albert
OK, thanks for the info.
