SamRichardsJr
8 years agoFreshman
Internet doesn’t work. WiFi light blinking.
I reset my modem trying to get my brother’s Xbox connected. Ever since then nothing connects. The power light is on, the WiFi light is blinking, and all the other lights are off.
- 8 years agoOk so I called HughesNet tech support over the phone. Which was extremely frustrating btw. They are sending me a new modem. Hopefully that fixes the issue.
8 years agoModerator
Hi Sam,
When you say "reset" can you describe what steps you took to reset?
-Amanda
SamRichardsJr
8 years agoFreshman
Unplugged for 30 seconds then plugged back in.
- SamRichardsJr8 years agoFreshmanI know you guys are busy but if someone could get back to me on this that would be great.
Amanda or another HN employee will likely respond to you today, but sometimes they're not available right away, so it might take a bit.
- 10 months ago
