SamRichardsJr
8 years agoFreshman
Internet doesn’t work. WiFi light blinking.
I reset my modem trying to get my brother’s Xbox connected. Ever since then nothing connects. The power light is on, the WiFi light is blinking, and all the other lights are off.
- 8 years agoOk so I called HughesNet tech support over the phone. Which was extremely frustrating btw. They are sending me a new modem. Hopefully that fixes the issue.
SamRichardsJr
8 years agoFreshman
I can’t connect to either of those links. My computer is connected to the modem with a wire but I can’t get internet with it either 🙁 Right now all I have is my cell phone internet.
SamRichardsJr
8 years agoFreshman
- Amanda8 years agoModerator
Hi Sam,
Glad to hear we're a step closer to getting the issue resolved. Please let me know if the modem change does not resolve the issue.
Thank you,
Hello Sam,
I see that the modem was delivered a couple of days ago and just wanted to check in and see if you've managed to get back online?
- Amanda8 years agoModeratorHi Sam, Just checking in to see if the modem replacement resolved your issue. We will mark the thread solved and closed in a few days if we don't hear back. Thanks, Amanda
- 10 months ago
