Internet not working, please help.
Hello Adrian1, welcome to the Community and thank you for reaching out! You've come to the right place and the information you provided thus far has been helpful for me. I pulled up your account and ran a diagnostic and see a bad alignment with the dish, but the error code you're receiving could also be related to a modem problem. To address your concerns, I've dispatched a technician to replace your modem and radio, and to re-point your dish.
The technicians have a busy schedule right now with the holidays, so I was not able to put you into a specific time slot. You will receive a call to the number we have on your account from a technician to schedule your appointment. To accommodate this, I've placed two weeks worth of credit onto your next bill.
I hope this takes care of everything!
-Brooke
I don't personally know what's causing the issue, as it could be a number of things. I only wanted to let you know to leave your HughesNet modem plugged in so that the reps have the ability to run remote diagnostics on your HughesNet equipment if they deem it necessary. Some people unplug their modem when they aren't using the service, so I thought it important to make sure you knew to leave it plugged in. It would also be a good idea to make sure that the coax cable connector at the back of the HughesNet modem is finger tight. It doesn't need to be tighter than this, but it shouldn't be loose.
The reps are on M-F from approximately 8AM to 5PM EST. Hopefully they'll reply tomorrow (Friday). :)
- Adrian1FreshmanThank you for letting me know. Everything is still hooked up. I left it that way just in case it decided to start working again.
- Adrian1FreshmanIt is now working very slowly and has a new state code. 24.1.1-- download throttled. Satellite recieve signal strength is 68. It is a clear blue sky outside.
-Brooke
- Adrian1FreshmanThank you all very much for your help. Brooke that is awesome ! Hopefully this does fix it all. Ill keep you posted.
