Issues working from home due to vpn? Unable to work from home
VPNs don't work well with satellite internet, unfortunately. (EDIT: but read this: https://support.hughesnet.com/en/faq/internet/can-i-run-vpn-over-hughesnet, and note that "HughesNet Technical Support does not provide help with configuring or troubleshooting problems associated with VPN clients.")
That said, the HN reps on the site, or someone else, may have tips or suggestions for you.
While HughesNet has been optimized to help those working and schooling from home, the very high system load as a result of so many more people being home and online can still cause things to not work as well as they normally would, unfortunately. And with VPNs not working well under normal circumstances with HughesNet, using one under the current conditions very likely compounds the issue. :(
