Modem Lights go off HT2000W-System, Transmit & Lan
Thank you very much Felicia. System is running like it should now. Tech knew his systems. Thank you again..
Hello Hunter74083,
I see it's your first post here, so welcome to the community! I am sorry to hear about your frustration with slow speeds. After running some diagnostics, I did find that we need to get a tech out to you. I have set you up for Monday Aug. 13th between 11:00 AM and 2:00 PM. If this date or time does not work for you, you can call 1 866 347 3292 and reference case ID # 114391568 to reschedule a better time for you. If you have any further questions please ask! Thanks!
*Felicia*
- Hardy7 years agoModerator
Hunter74083,
You are very welcome! Glad to hear you're up and running again.
