winsome31
2 years agoNew Poster
Port Forwarding on HT3000 (Jupiter 3 plan) DOESN'T WORK
This is a new site install of HT3000 (Jupiter 3 plan using DHCP for WAN) and cannot get Port Forwarding to work. Most of my other sites are HT2000 (Gen 5 plan using DHCP for WAN) and port forwarding ...
winsome31
I did call and they couldn't help as said port forwarding was not supported which seems odd as it is a configurable item on the GUI. Is there another resource to post my questions?
winsome31
Please note my internet is up and all good. Also, I am not trying to ping from my hughes out to the internet. It is the other way, pinging from internet to the hughes HT2000 which is failing since day 1. I have 7 hughes at different sites and this is the only one that is not pingable. I confirmed that the configuration for Intrusion (IDS) is unchecked for "ping to wan interface"
