Intermittent no system light on HT1100 modem
I've got green check marks all the way across top to bottom for 48 hours in the diagnostics. I don't think it is anything I did but appears to be fixed.
Hello Amanda,
Last Friday I was about to hit send with the answers to your questions when I got a text from AllPro Satellites wanting me to confirm a Saturday Morning appointment. I called them and talked to Jonathan, the install manager.
I described the problem I was having and told him I needed a few days to check some things on my end and if he would, put the appointment on hold which he did.
The questions you asked about the power and if I was on a surge protector made me think that very well could be the problem. Because it has been on a 2160 joules Philips surge protector for 17 months, I thought I would try it direct to a power outlet.
So, Saturday it went out briefly at 1:30 pm while I was streaming an internet radio station and by checking the diagnostics I saw that it went out for a few minutes early Sunday morning. Those outages are not a big deal to me and I though it was pretty much normal, so I thought my problem was in fact a faulty surge protector.
Sunday, at almost the same time, about 1:30 pm it was going on and off for about 45 minutes. It has always been around that time of day. Friday It was out at 11:00 am but it seems to always be between 11 am and 2 pm which makes me think that it is on my end.
And did I say that I put the modem direct to power? Well, it is on a 50 foot 16 gauge extension cord that is plugged into a laundry room outlet. That outlet is on a double breaker to make it 240.
When I lost power in the 2 living room outlets back in May and moved the surge protector to the extension cord to the laundry room, that could have been the beginning of my problems.
What do you think? Are extension cords bad for a Hughesnet modems?
- 26 days ago
