System light won't stay on
Good morning mcoleman,
Thank you for the updates. As a courtesy, I'm dispatching a technician to do a complete review of your site due to the concerns you've been encountering. Your dispatch is currently scheduled for our earliest available slot: Thursday, Jun 28, 2018 between 11:00 AM-02:00 PM. Call us at 866.347.3292 and reference case #113385787 if you need to reschedule. Please let us know how the site visit goes.
Great!
I realize now that you won't find the term "SQF" in the System Control Center (SCC), instead look for "Satellite Receive Strength", I'll need the number next to that please.
Sorry, i didn't get your last message in time. The 2 codes it has set are 12.7.1 and 12.8.1 and the TCP Accel says fail. I'll check the signal strength tonight when I get home.
- Liz8 years agoModerator
OK thanks, please also let me know if powercycle makes a difference.
- mcoleman8 years agoFreshman
I still just get the system light back temporarily and then I loose it again after powercycling. I'll get the signal strength number tonight.
Signal strength is 68 and we powercycled it again with the same results of the system light eventualy going back out within 10 minutes.
