System will not boot
- 8 years agoOver 12 years and HughesNet has taken care of me again. Thanks Amanda.
Looks like I can access 192.168.42.1 through the LAN and access the wifi portion of the router. Still cannot access 192.168.0.1 on the LAN. Wifi connects but no internet.
Hi dzfire,
This is definitely odd - it could be that another gateway address is set on the device you are trying to use (192.168.1.1). Do you have any other devices you can test? Are all of your lights on the HughesNet modem lit or just a couple, like in your original post?
Thanks
- dzfire8 years agoSophomore
Only two lights are lit, power and wireless.
- GW8 years agoAdvanced Tutor
Try disconnecting the power and then the coax. Let it rest for a few. Reconnect coax and then the power. Maybe it will boot. This has worked many so many times for me I named this procedure the coax dance.
Tried the disconnect last night ;) As a side note, I've been using HughesNet since the days of DirecWay out here and have been happy with it for the most part. Just gotta get back up and running so I can start work taody. :D
