David_78933's avatar
David_78933
6 years ago
Solved
Transmit / Uplink Problem
My Hughes system has started having transmit problems (state code 12.1.9) today. I rebooted the HT2000W modem once, when we lost internet access all together, and it helped to clear the problem for about an hour. But it has started to resume now. Web acceleration also drops out frequently, and I have to reset it. We have clear weather here, so it is not a rain/storm related issue. The modem is only a couple of years old. Any thoughts?
  • Remy's avatar
    Remy
    6 years ago
    David,
    You are currently on our older Gen4 Power Pro plan, which is advertised at speeds of up to 10mbps download and up to 2mbps upload. Our Gen5 plans are where we offer 25mbps down and 3mbps up, and I'd strongly recommend calling in to 1-866-347-3292 for more information on a possible upgrade to it!
    Remy
  • Here's a Monday morning update on my situation. The transmit / uplink problem has continued unchanged all weekend, and the State Code Monitor shows it out of commission about as much as it is working. Email only sends and receives sporadically. No change from daytime to night time. Line of sight to the satellite is clear, and the receive signal strength remains strong. I power cycled the modem on Sunday morning, rather than rebooting from the App. That had no impact on performance. The modem AC adapter is plugged into a UPS, with a steady 121-123V output. I tagged my initial post for Amanda, who had helped me last time I had an issue in 2018, but it doesn't appear that she hasn't been active for Tech Support since last year. Hopefully someone else will address my post if that's true.
    • Remy's avatar
      Remy
      David,
      Thank you for posting! I was able to look into your account and keep up with the errors you've been keeping track of. The normal culprit of these issues is either a Gateway issue, as maratsade and Gabe were discussing, or a general alignment issue. I looked into both, and neither seem to be an issue. In that case, the most likely issue is the equipment malfunctioning, and I've seen an influx of errors within the modem itself. I'm going to be sending you a new modem, with the fees waived. When you receive the box, it'll have a prepaid shipping label meant for return of the previous equipment. Please let us know if this new equipment resolves your issues!
      Remy
      • David_78933's avatar
        David_78933
        Thanks, Remy! Any idea how long the new modem will take to get here? And will there be instructions with the new modem, or is plug & play?
  • I've been having this same exact issue starting tonight.  I have an older Gen 4 system and I've been suspecting that age is catching up to it.  The weather here is fine, clear, sunny, and hot.  Best I can figure the gateway is in Montana, the weather is clear there as well.  I did some research and people with similar problems have had radio issues.  So I called and upgraded to Gen 5 hoping that it upgraded the transmitter as well.  Turns out that it doesn't.
    I called a tech who had me reboot the system.  Of course, it cleared the error state (I had done this before), and seeing that the board was green he didn't see a need to do anything else.  So in frustration I just went with the upgrade.  It needed to be done anyway, but somehow, I seriously suspect the radio is succumbing to heat/moisture.
    Of course, within a half hour it glitched again.
    Any help is appreciated.  It could be something temporary on Hughesnet's end.  I've noticed that recently I've had more glitching, I've just now started watching it more closely.
      David_78933
      My modem and radio were both replaced two years ago. I would hope those major components would last more than two years, but...? It's definitely hot here in Texas this week, but it gets this hot every summer.
        They're probably fine. The problem may be at your gateway or it may be issues with your beam. What beam are you on?
      Don, you will need to start your own topic under Tech Support. Go to the Tech Support page, click on the "start a topic" button and post your issue (you can copy and paste from here). The mods address tickets separately, and it's very likely your post here will go unanswered by them unless it's under its own ticket.  The mods are here M-F during business hours.
    Weather issues at the gateway can affect your signal too.  If there's a problem at the gateway, it's usually temporary. The mods here can probably check your system remotely and see what's going on. Give them some time to respond.
      David_78933
      Thanks. I should have mentioned that there is no weather in Wyoming at the gateway, either.
        Best to let the mods check to see whether there's an issue at your location or something going on at the ground station. They usually respond within a day or two, but if you're in a hurry, you can always call the customer service number (24/7) or use the chat.
