Why is my WiFi settings in Spanish
Is the rest of the System Control Center in Spanish or English? http://192.168.0.1/#!/usage
If Spanish, you should be able to change it there. If it's not, I'd try changing it to Spanish, then back to English, and then login to the WiFi settings to see if they're back to English.
If that doesn't work, have you tried power cycling the modem? That's unplugging it at the wall outlet or power pack (NOT at the back of the modem), waiting at least 30 seconds, then plugging it back in and waiting about five minutes for it to be fully back up. This may reset the language so that it's the same throughout (English). If not, I'm sure the reps will be able to help.
- 11 years ago
