jenbeth5
8 years agoSophomore
Why is my WiFi settings in Spanish
ok I click on Wifi http://192.168.42.1/login.htm it is in Spanish ... how do I change it back to English ? I try to click on the Spanish in the top right corner and it dose nothing ...
Is the rest of the System Control Center in Spanish or English? http://192.168.0.1/#!/usage
If Spanish, you should be able to change it there. If it's not, I'd try changing it to Spanish, then back to English, and then login to the WiFi settings to see if they're back to English.
If that doesn't work, have you tried power cycling the modem? That's unplugging it at the wall outlet or power pack (NOT at the back of the modem), waiting at least 30 seconds, then plugging it back in and waiting about five minutes for it to be fully back up. This may reset the language so that it's the same throughout (English). If not, I'm sure the reps will be able to help.
- 11 years ago
