WiFi booster wired connection
I don't think it works that way. You connect it to the modem to sync the booster with the modem. After setting up the booster, you have to disconnect it from the modem, as the booster needs to be moved to a location halfway between where you have good signal and where you have low or no signal. Once there, the booster needs to be plugged in so it can extend the signal. It's not a hotspot, it's an extender.
BillSquared wrote:
I need to extend my existing Gen 5 service to a small outbuilding about 200 feet from my main router, and the wireless signal doesn’t reach that far. The WiFi booster has a wired port on it for initial setup. Can that be left permanently connected to extend the range over a wired connection for the first 200 feet and then create a WiFi hot spot in the outbuilding using the booster?
