Wireless Router problem??
It's probable that the performance of the laptop, at least when it comes to things like opening and running basic programs and such, is faster due to it being more integrated. Feed it something more intensive and it will most likely fall behind the desktop, and quickly.
Hello bos2420, the honest answer is you are on a legacy satellite that may not be up to optimum speed.
That said, you could have other hardware issues on your end.
Plugging a computer directly into the modem will help eliminate the router being the problem.
Honest opinion, time to upgrade again. Upgraded to 9000 a year ago? That was not much of an upgrade.
Hopefully the new satellite (Gen5) means you have a better option.
Think of it like switching from dial-up, to dsl, to cable, and then to fiber. Is the same progression on satellite. From 4000, to 7000, to 9000, to 1100, to 2000.
- bos24209 years agoJunior
First, thank you for at least replying to my issue....
Yea, the modem and router are in another room. Not gonna happen. This is literally my LAP top computer.
Actually, it was. I was on a 4000 when I upgraded. Didn't even WANT to upgrade, but they had no 4000 modems, or at least the one the installer/repairman had could not be made to work. Thus, the upgrade, which was the ONLY upgrade available then.
Again, 'hopefully' isn't an answer I am looking for.
Maybe you missed the part where I am a 12 year customer. I keep up on this stuff, I know what is out there.
Again, I have ONE specific question. Should the display of the System Control Center be tied to poor signal reception, or should I get a good display of the SCC regardless of signal. See, if it is the 2nd situation, then the ROUTER is my problem. I would need to replace my router.
If it is the 1st answer, then my router is FINE, and it is just signal loss. It happens often, regardless of weather or other conditions, for anywhere from 3-30 minutes. It is annoying, but satellite in general is annoying, compared to a cable connection, but that doesn't matter, because satellite is the ONLY option where I live.
And, once again, I am NOT complaining about my service. I am asking if the drops in connections are because of MY hardware. That I can fix. But I need an answer to my question before I spend the money.
Yes the SCC should come up.
Reasons why it may not:
IP address between the router and the modem. The Modem is hardwired for 192.168.0.1
That address can not be shared.
The Routers LAN IP should be set to 192.168.1.1 to avoid conflict.
DHCP should be enabled in the router.
There is a "connection path" of 192.168.1.1 (router), next station along the path is 192.168.0.1(modem).
If you lose, for whatever reason connectivity to the router you then lose connectivity to the modem then hence your connection to the internet.
Are you using 2.4 or 5.0 Ghz for wireless?
Well, I got off my lazy butt and looked. It is a WD N600. Specs show it is Dual-Band, 2.4/5 GHz. I have not messed with any settings, or dabbled with it since I installed it. I am good on computer stuff, software problems and such, not so much on hardware.
The router is set to 192.168.1.120 (which I assume is no problem)
The reason I started all this is because it only made sense to me that the SCC should show up, regardless of satellite signal problems. It seemed it should be static information that is available at all times, via the modem. We have been having this problem for about 6 months, and I finally got around to searching for solutions. The SCC page idea hit me. If the SCC is not popping up right away, then the signal from the Router should be at fault, not the modem or signal. In the past, *older modem, 4000* the SCC always came up, usually with the Red or Yellow problem buttons.
Again, no connection problems on other wireless connections, including my phone hotspot. So, I was discounting the computer as a problem.
Thank you for the reply.
