sli-er_15
4 years agoSophomore
HN7000S ethernet cable
My internet connection has been off for a while and I'm wondering if it has something to do with my current ethernet cable. My quick online search shows that the HN7000S modem uses an RJ45 cable. Whe...
4 years agoDistinguished Professor IV
You can use a CAT5 cable, and it may be that the speed capabilities of your particular system wouldn't reach the point that you'd see the advantage of the higher speed capabilities of a CAT6 cable, but if you have to buy one I'd still go with CAT6 for the sake of "future proofing".
- 5 months ago
