spydermike
5 years agoSophomore
Playon having issues with slow download speed?
I have tried to find a solution to actually be able to use our HNS service for something other than just emial and very light browzing (no videos). It was suggested here that Playon could be a solut...
spydermike
4 years agoSophomore
Not even close...about 2000 satellites up there now I think. I think you are referring to a single launch of about 50 satellites that went up when the flare hit and some /most of those were affected before they were positioned. The service is working fine as far as we can tell. We are getting over 100 times better speed not to mention the much improved latency. The way it should be.
Oh, and I installed the system in about 10 minutes as the antenna assembly self aligns.
- MarkJFine4 years agoProfessor
Knew the dish 'electronically steered' itself. I would think it almost had to given the elliptical orbit.
