Ricky, have you tried to use Windows Update to see if the computer could find a generic driver online to use?
It's a long shot, but sometimes Win7 and Win10 drivers will work on Win 8.1.
Hopefully this article from Brother will help: http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=mfc240c_all&faqid=faq00002994_002
I have but the updates failed. Trying them 1 by 1 now to see which one fails. I know the Brother one failed. Sounds like a project tomorrow.
Have you tried to manually add the printer and manually select the driver like we used to have to do back in Win98 days...?
- Ricky8 years agoTutor
No not yet Corrosive. Thanks for the tips. I will be signing off for tonight soon. So I will check back in tomorrow around 11 EST to see any ideas and get to work on trying to get this thing working.
- Gwalk9008 years agoHonorary Alumnus
What version of Windows was listed for the last driver?
Did you try installing the driver as an Admin?
Did you try installing under compatibility mode?
- 10 years ago
