I have but the updates failed. Trying them 1 by 1 now to see which one fails. I know the Brother one failed. Sounds like a project tomorrow.
Have you tried to manually add the printer and manually select the driver like we used to have to do back in Win98 days...?
- Ricky8 years agoTutor
No not yet Corrosive. Thanks for the tips. I will be signing off for tonight soon. So I will check back in tomorrow around 11 EST to see any ideas and get to work on trying to get this thing working.
- Gwalk9008 years agoHonorary Alumnus
What version of Windows was listed for the last driver?
Did you try installing the driver as an Admin?
Did you try installing under compatibility mode?
I do not know what version was listed for the last driver. I did not investigate to much yesterday. I am trying to install as a Admin. though. I have not tried to install in compatibility mode. All things I will have to try later today.
Thanks!
- 10 years ago
