No not yet Corrosive. Thanks for the tips. I will be signing off for tonight soon. So I will check back in tomorrow around 11 EST to see any ideas and get to work on trying to get this thing working.
What version of Windows was listed for the last driver?
Did you try installing the driver as an Admin?
Did you try installing under compatibility mode?
- Ricky9 years agoTutor
I do not know what version was listed for the last driver. I did not investigate to much yesterday. I am trying to install as a Admin. though. I have not tried to install in compatibility mode. All things I will have to try later today.
Thanks!
According to the Brother site the built-in Windows 8.1 drivers are supposed to work: http://support.brother.com/g/b/downloadlist.aspx?c=us&lang=en&prod=mfc240c_all&os=135
Not sure why you can't get it to work. I have a Brother MFC-430JW and the built-in drivers are working. What shows up in Control Panel/Decices and Printers, anything? Is Windows up to date?
Maybe this will also help:
http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=mfc240c_all&faqid=faq00002994_002
- 10 years ago
