What version of Windows was listed for the last driver?
Did you try installing the driver as an Admin?
Did you try installing under compatibility mode?
I do not know what version was listed for the last driver. I did not investigate to much yesterday. I am trying to install as a Admin. though. I have not tried to install in compatibility mode. All things I will have to try later today.
Thanks!
According to the Brother site the built-in Windows 8.1 drivers are supposed to work: http://support.brother.com/g/b/downloadlist.aspx?c=us&lang=en&prod=mfc240c_all&os=135
Not sure why you can't get it to work. I have a Brother MFC-430JW and the built-in drivers are working. What shows up in Control Panel/Decices and Printers, anything? Is Windows up to date?
Maybe this will also help:
http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=mfc240c_all&faqid=faq00002994_002
- 10 years ago
