Ricky
9 years agoTutor
I have aquired a Brother MFC-240C printer. I can not get it to print. I did not get a install disk with it. I can see the printer. The printer will make a copy of something so it will work. I just do...
9 years agoDistinguished Professor IV
Might there be an issue with the USB cable? Have you tried it in a different USB port?
Ricky
9 years agoTutor
I just tried a different USB port and still no go.
Windows does have some updates that are needed but they keep failing. Trying to figure that out 1st since maybe that is the problem right there. Attachment is what shows for printers.
Problem solved...... I was not choosing the right printer to print to. Hahahaha. I must have taken a stupid pill this morning. Thanks for the help guys.
- 10 years ago
