I just tried a different USB port and still no go.
Windows does have some updates that are needed but they keep failing. Trying to figure that out 1st since maybe that is the problem right there. Attachment is what shows for printers.
Problem solved...... I was not choosing the right printer to print to. Hahahaha. I must have taken a stupid pill this morning. Thanks for the help guys.
I look at everything as a learning experience and something that will help you next time. :)
- Ricky8 years agoTutor
Now if I can just get the updates issue resolved.
I learned that because I had a problem logging into my computer a few months ago my windows was not activated. I could not log into my computer at all and to reset it. I guess that caused my windows to not be activated. So off to find the key. Not on the paperwork. But thanks to Belarc I believe I have it. Lets see how the updates go this time.
Wish me luck. hahahahahaha. It is always fun around here with me and this computer.
Unfortunately, Belarc sometimes gives false keys. If it was a name brand, pre built computer, like a Dell, HP, etc, and it came with Windows 8 or later, it may have come with an embedded product key. If this is the case, it should automatically activate when you go online.
It is a Acer. Belarc was spot on this time. A check shows Windows to be activated now. Still waiting on updates results.
- 10 years ago
