Good to hear. Hopefully everything will work with the updates. There are probably a lot of them, and if they fail, I can point you to a post that might help, as I had a problem updating a clean install of Windows 8.1 and got help from a Microsoft tech. There were some prerequisites that I needed, but this was with an install from W8.1 install media downloaded from Microsoft.
Actually GabeU there are only 3 critical and 3 optional. Will post back when I know something. They seem to be taking there sweet time downloading. Speeds are good though.
- Ricky9 years agoTutor
Problem solved. I had a couple services that got turned off somehow or not started somehow. A chat with Microsoft fixed that issue. Updates downloaded and installed fine.
Nightmare.
I thought all this was solved. Not only are my updates failing but I have no programs starting up. What a mess. Attempting a re-install from my external harddrive.
Ricky, before doing that I would run a chkdsk /r on the drive first. It can take quite awhile though. I've had success with it fixing screwy problems in the past. How old is your drive?
chkdsk /r /f would be a better option.
The "/f" is inherent when doing the "/r" command.
Hrm, I have for some reason always ran /r /f, never knew that /r would also perform the same operations as /f
Not a big deal, just not needed is all as "r" has to do an "f" first in order to attempt any sector repair.
Ricky, you may want to check the S.M.A.R.T. statistics on the drive also. Will show if read/write is starting to fail.
This has been a mess. I have Acronis 2017 to back up my computer. It did back it up and the backups were validated. However the software for some reason would not start up. So I have just started over. Fresh install and downloading my programs again. Hope the next adventure is better.
Sheesh! I sure hope everything goes well for you this time.
- 10 years ago
