sli-er_15
5 years agoSophomore
HN7000S ethernet cable
My internet connection has been off for a while and I'm wondering if it has something to do with my current ethernet cable. My quick online search shows that the HN7000S modem uses an RJ45 cable. Whe...
You can use a CAT5 cable, and it may be that the speed capabilities of your particular system wouldn't reach the point that you'd see the advantage of the higher speed capabilities of a CAT6 cable, but if you have to buy one I'd still go with CAT6 for the sake of "future proofing".
- 4 months ago
