pfrazer
7 years agoFreshman
TLS handshake failure between IoT product and AWS
Hello, I am a software developer building an IoT water treatment product that is currently in soft release. (https://dropconnect.com) The core of the system is a WiFi-enabled hub that commun...
In the end, the problem was corruption of the TLS handshake caused by a default buffer size in Microchip's TCP/IP library being too small. I haven't completely studied the cause yet, but it appears that traffic received via a HughesNet link uses a larger than typical MTU setting or something along those lines. Simply resizing that buffer made the problem disappear.
Patrick
7 years agoModerator
Hi Patrick,
I'm glad you found the community, thank you for posting. Wow, I admire your dedication to finding a solution. Let me send this over to our engineers for their input. I'll post back once I hear anything.
