farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired desktop. Appreciate your suggestions. I did go into netgear and check for updates and all was fine.
- Hey farmerhugh
Thanks
- C0RR0SIVEAssociate ProfessorWhen you say "wifi keep shutting down" do you mean your wireless device disconnects from the wifi, then comes back when you turn on a wired machine? Sounds like the wireless radio on the router could be dieing if that's the case.
- farmerhughJunioryes. thats exactly it. Guess i'll be buying a new one...Any suggestions?? I've seen references to the Asus. its just us old folks so we don't need a lot of bells and whistles--probably wouldnt even know what to do with them..lol
- AmandaModeratorHey farmerhugh
Thanks
Amanda - Gwalk900Honorary Alumnus
farmerhugh,
One thing you may wish to check for each computer is the power settings for the network adaptor.
This is from Win7 but others are similar:
- farmerhughJuniorIf there;s no charge that would be great. I'm getting mighty tired of running into the other room to reset the router, Thanks
- farmerhughJuniorWould the network adapter suddenly change. Its been fine until about 5 days ago. We did have a snowstorm and at first i thought that was the cause. Sent Hugh out a few times to dust off the satille dish, but snow is no longer an issue.
- farmerhughJuniorwould this b it? this us just one laptop. its happening to another also.
- farmerhughJuniorWrite a reply
- BirdDogAssistant ProfessorNo. Control Panel>System>Device Manager>Network Adapters then click on whatever wireless adapter is installed on your computer. Should then see what Gwalk posted.
- AmandaModeratorSure no problem farmerhugh, ordering you one right now! Should be there next week :) Comes with set up instructions in the box and it is yours to keep forever.
- 11 years ago
