farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired...
- 9 years agoHey farmerhugh
Thanks
C0RR0SIVE
9 years agoAssociate Professor
When you say "wifi keep shutting down" do you mean your wireless device disconnects from the wifi, then comes back when you turn on a wired machine? Sounds like the wireless radio on the router could be dieing if that's the case.
- 11 years ago
