farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired...
- 9 years agoHey farmerhugh
Thanks
farmerhugh
9 years agoJunior
If there;s no charge that would be great. I'm getting mighty tired of running into the other room to reset the router, Thanks
- 11 years ago
