farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired...
- 9 years agoHey farmerhugh
Thanks
farmerhugh
9 years agoJunior
Would the network adapter suddenly change. Its been fine until about 5 days ago. We did have a snowstorm and at first i thought that was the cause. Sent Hugh out a few times to dust off the satille dish, but snow is no longer an issue.
- 11 years ago
