farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired...
- 9 years agoHey farmerhugh
Thanks
BirdDog
9 years agoAssistant Professor
No. Control Panel>System>Device Manager>Network Adapters then click on whatever wireless adapter is installed on your computer. Should then see what Gwalk posted.
- 11 years ago
