farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired...
- 9 years agoHey farmerhugh
Thanks
9 years agoModerator
Sure no problem farmerhugh, ordering you one right now! Should be there next week :) Comes with set up instructions in the box and it is yours to keep forever.
- 11 years ago
