farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired...
- 9 years agoHey farmerhugh
Thanks
farmerhugh
9 years agoJunior
does this look ok?? I am soo confused. But really trying to check it all out. really appreciate your help. The ethernet is checked the samr.
- 11 years ago
