farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired...
- 9 years agoHey farmerhugh
Thanks
Gwalk900
9 years agoHonorary Alumnus
May not be the issue in your case but is one less thing out of the way.
Don't forget to post when you get the new router
- 11 years ago
