I would like to downgrade my plan. Will it take effect immediately or at the start of a new cycle?
Solved! Go to Solution.
I'm 99% sure that it will take effect the moment the upgrade is put through, not at the start of the new cycle, and the cost difference will be prorated. A rep can tell you with certainty. I'll tag a couple so that they can reply and give you a definitive answer. 🙂
Exactly what Gabe said. 🙂
