Gen 5 Speed
Shortly after our HughesNet service was installed it appeared I made a mistake. Our internet speed is certainly slower now, heavy data consuming pages take 30-45 seconds to load, YouTube videos play in the worst resolution format due to buffering, and I can’t get anything to stream to my TV at all. I also had HughesNet provide me with phone service which is also terrible. There is a decent delay between what’s said and what’s received on the other end. It reminds me of when my Father was in the Navy and would call us from overseas in the 90s.
What am I missing here, why do I not see the higher speeds HughesNet brags about?
The delay is normal with satellite communications, you will see approximately 600ms in delay between you, and the other party on your voice service.
As far as buffering goes, make sure that you set your resolution to Auto-Detect, or, at most, 480p. Alternatively, if you wish to watch videos in 720p or 1080p, you must disable the Video Data Saver option, as this throttles video stream connections to help save data. You can read more on what the Video Data Saver is, and how to disable it here.Another thing you will want to keep in mind is if you exhaust your data, your speeds will be decreased to approximately 1Mbps or slower.
As far as speeds and how fast websites load, because of latency, websites will feel sluggish to load, however, the data is transmitted at the highest speed possible at any given time. If you wish to troubleshoot your speeds after taking the first few things into account, then please create a testmy.net account and perform 3-5 tests during different parts of the day. Then share the account results link with us here.
Tests from other sites like speedtest.net are not accepted due to the compression technologies and latency that are seen on satellite communications.
-use the 25MB size download test file ONLY
The Reps are on M-F from approximately 8AM to 5PM Eastern. - dacarriganSpectator
Gen5 speeds are still probably way below the National avergaes for up/down loading
- 12 months ago
