Our connection has been dropping quite often, especially today. I think this has been going on for a few days now, as I have had breif connectivity losses on a regular basis, but today it has been quite frustrating. I attached some screenshots to show what's been happening. The modem's lights twinkle quite a bit while the network is up, although sometimes it seems we loose connection even while the lights suggest otherwise (maybe it's just a breif loss?). At other times the sattelite link lights are completely down.
Here's a few of the thoughts I had:
Could there be a bunch of storms in the gateway's area? It has been clear here.
We have had some strong winds lately, and that may have misaligned the dish.
We do have tall trees in the area, but I think they are clear of the path of the dish.
I have not yet rebooted the router, but shall do after posting this. I will also make sure the dish is connected to it well.
Thanks for your help.
Solved! Go to Solution.
Hello
Thanks! I poked through some e-mails while waiting... I'm not particularly fond of referencing the weather, but there have been multiple reported weather-related degradations for your gateway (located in Omaha, NE) that would have caused slow or intermittent connectivity.
These occurred in bursts on: June 10th, 11th, 15th, 17th, 18th and 19th.
If you experience the issue again, please let me know and I can look into it.
