Hughesnet Community
Unable to connect to System Control Center
jeffreygrant717
Good day all, having an issue where I'm fully connected & enabled via Hughesnet Modem & Internet, but I try and launch the "Control Center" and it takes me straight to an error page: "Unable to connect to System Control Center" (https://my.hughesnet.com/support/faq/3844/)
Any ideas how to get this URL to operate properly?
1 ACCEPTED SOLUTION
3 REPLIES 3
You're actually on the Hughesnet network when you're trying to connect, right? You need to be at home to be able to connect to the SCC.
skid5150
Are you using this URL?
http://www.systemcontrolcenter.com/#!/usage
If still having issues try
try http://192.168.0.1/#!/home
thanks skid - you solved my issue
solution:
connecting to: http://192.168.0.1/#!/home
