Re: Unable to load Amazon, Problem Upstream From Modem
I might have to keep an eye on AdBlocker Ultimate.  I have Adblock Plus, which is pretty much what's usually recommended and is used by a slew of people, but AdBlocker Ultimate looks interesting.  Maybe I'll give it a try on my laptop and see how it compares.
Hi everyone,
I will be finding out more today on the status of resolving this.
On a side note, I use both Adblock Plus and uBlock Origin. I feel uBlock is very aggressive in auto-closing unwanted browser tabs before they can hijack your browser.
~Amanda
@Amanda, thanks for the update!  Amazon is so messed up when I login I've been shopping at Target (brick and mortar), instead.
Sure thing! Well, so far it is the same status, it is being worked on. I will keep you updated as always.
~Amanda
I used to use uBlock Origin, as well, but forgot to add it back in after performing a clean install of the W10 Fall Creators Update.  I didn't realize it helped with this, so I'm going to reinstall it immediately.  Thanks for the inadvertent reminder.  Smiley Happy
Good morning everyone,
Thank you,
@Amanda,
Yes, mine is working now!  Thank you!!!!!!!  Man Very Happy
Thank you for the feedback Gil!
Just wanted to check in with everyone who posted here about being unable to load Amazon properly. Has this been resolved for everyone?
~Amanda
