rcrhome
10 years agoNot applicable
Asked for a rebate for a new referral but forms are not understandable
Forms for rebate and information
CommunityWorklo
10 years agoNew Poster
Good morning rcrhome,
Thanks for posting, the only way to check on the status is through that site. When I tried to fill out the registration info on the Refer a Friend site, it said you were already registered, so there's that at least.
If you try to log in, you'll see this page:
https://hughesnet.getambassador.com/login/
Beyond that, you should be able to check on the Refer a Friend rebate status.
- 10 months ago
