Confirmed Hughes System Error Costs Me Hundreds (Token111 error)
Hello,
It has been a while since we heard from you so this thread will be closed. If you have any further questions or concerns please create a new thread.
Thank you,
Wow. What a nightmare. Sorry you had to deal with that.
With that said, in case you aren't aware, though there is no pie graph for data tokens, there is a spot on the Usage Meter and the various other places that your remaining data is shown. It's shown as Token Bytes Available. On the Usage tab of the MyAccount site it shows as Data Tokens Available. On the System Control Center, just Token Bytes. And, when you have tokens available like this, the usage of the token data will automatically kick in when you exhaust the data in one, or both, of the other two data banks, depending on the data time period your presently in while online. IOW, from 8AM to 2AM, it's Service Plan Data, then Token Data. From 2AM to 8AM, it's Bonus Zone data, then Service Plan Data, then Token Data. During each of the two time periods, the successive data bank kicks in automatically when the preceding one is exhausted. This is just for info in case you aren't aware of how the data is used and how the successive data bank kicks in automatically.
The tokens I have were collected over a few years. I had some when I came from my old plan, got a few from the two outages this year (Jan and Sept), and got some for doing some speed testing in the past.
When I upgraded to Gen5 I chose the 20GB plan, and it has been enough for me. If I still had Gen4 and upgraded to Gen5 now I wouldn't have the choice of a larger plan, as the 20GB plan is the largest they are offering on my beam these days. I have yet to need any of the tokens I have, though they're ready to go, just in case. I should just suck it up and go on a bit of a streaming spree! :p
There's no 50GB token purchase available, though if there were the price would be the same as two 25GB token purchases, as when you break all the options down the tokens are $3 for each GB, regardless of how much you buy. It's a little odd that they don't give something off for the larger purchases, like maybe offering the 25GB token purchase for $70, or even $65, but they don't, unfortunately. :(
